Group: DynoMotion Message: 8054 From: Toby Rule Date: 8/1/2013
Subject: generating pulse train in DSP
Is it possible, using the KFLOP, to generate a pulse train with the following characteristics:
Frequency range: 50-300 Hz
Pulse width range: 50-300 microseconds
I will need to control frequency and direction from within a DSP control loop.
I have achieved some degree of success using a C-program, but I need two threads to do it, because of the 90 microsecond time slices. Using this method, the pulse width isn't as accurate as I would like.
Is there an alternative way to do this? Maybe I could use one of the motion axes, but I'm not sure if I could vary the pulse width.
Toby
Group: DynoMotion Message: 8055 From: Tom Kerekes Date: 8/1/2013
Subject: Re: generating pulse train in DSP
Hi Toby,
I can't think of a simple way to do this.  But I don't fully understand what you are asking for.  Do you need all of those frequencies and pulse times?  Or just one or some of them?  With what resolution or granularity?
I assume you are aware of the 8-bit PWMs.  But they don't go to that low of a frequency:
16.67MZ /256 /256 = 254Hz min
The Step/Dir Generators can give the frequencies you desire, but at fixed pulse times of 3.78us max.  With a bit of external hardware like a Set/Reset Flip Flop you could probably do it using two Step/Dir Generators set to the same frequency but with one delayed.
There is a User Callback capability which allows a User Program to do something every 90 us.  This is better than normal user programs which basically execute every 180us.  But still wouldn't meet your requirements.
